-   EnSight (http://www.cfd-online.com/Forums/ensight/)
-   -   Ensight - Hide coupled cells in transparency mode (http://www.cfd-online.com/Forums/ensight/16212-ensight-hide-coupled-cells-transparency-mode.html)
Benni January 15, 2009 05:11
Dear Users,
I'm using Ensight Gold Version 8.2 to visualize my results from a StarCD Simulation. The mesh contains some so called couples. Everything works fine in Ensight, but when I use the Transparency mode (opaqueness ~ 30) you see these nasty coupled cells of the mesh. Link
Does anyone know how can I hide these cells in the transparency mode?
Thanks a lot for your answers
Best regards Benni
link to the image: http://image-upload.de/image/1phDA0/0596c329d1.jpg
Balduin Bankerotti January 15, 2009 07:21
Re: Ensight - Hide coupled cells in transparency m
Create shells on the surfaces and use a set file for exporting to ensight.
The export looks something like:
system
rm case.set
evfi conn
trfi conn
trload,,
c
cset news type 3
cset add type 7
cset add type 8
setwrite ,case.set, FLUID1
cset news type 5
setwrite ,case.set, Fluid2
cset news type 2
setwrite ,case.set, Fluid3
cset news type 10
setwrite , case.set , shell_part1
cset news type 16
setwrite , case.set , shell_part2
cset news flui
store first
direction,write
ensi,root,ENSI
ensi,form,bina
ensi,all,cavg, case.set
ensi,done
The shells have to be after the fluid cells in the set file.
