Home > Forums > EnSight
KIVA: Ensight:
Old   April 18, 2005, 18:35
Default KIVA: Ensight:
Sasidhar
Hello everybody, I am trying to use ensight for KIVA analysis. When I run the main code keeping otape9 as formatted file I get the following error message.
dtcon= 1.00000E+20 dtacc= 5.00000E+19 dtrst= 5.19615E+04 dt= 1.50000E-06 ncyc= 0 ca=-190.00 t= 0.0000E+00 dt= 1.5000E-06 gr= 0.000 tmax= 4.0000E+02
gasoline= 0.0000E+00 pm= 0.0000E+00 pcyl= 4.0000E+06 avt= 4.0000E+02 maxm
0 -190.0000 0.0000000E+00 1.5000001E-06 400.0000
3999997.
iters: y= 0 v= 0 t= 0 p= 0 k= 0 e= 0 big= 0 nfluxs= 1 pgs= 1.0000E +00 forrtl: severe (256): unformatted I/O to unit open for formatted transfers, unit 9, file C:\Documents and Settings\sasidhar\My Documents\kivaensight\otape9.dat Press any key to continue
And when I change th otape9 to unformatted file, I am able to run the main processor but I get the following error message while running the post processor code
Reading input file
forrtl: The system cannot find the file specified. forrtl: severe (29): file not found, unit 9, file C:\Documents and Settings\sasi dhar\My Documents\kivaensight\otape9 Press any key to continue
Can anyone help me with this. I am using the fulout.f and k3tom5.f files as suggested by ensight. thanks in advance
Old   April 19, 2005, 03:05
Default Re: KIVA: Ensight:
P
Hi, Do you know that you can write your data in gmv format and use gmv software for doing visualisation and also in tecplot 10.6 you can impost this data. It seems that you are indian student. I would like to know where are you working with which group. P
Old   April 19, 2005, 03:24
luis
The KIVA->EnSight translator http://www.tfd.chalmers.se/~nordin/ensight.html
Thread Tools
Trackbacks are On
post processing of Kiva results using ensight vedhusiva Main CFD Forum 1 June 24, 2010 12:36
PDF - conserved scalar approach in KIVA vega Main CFD Forum 0 July 5, 2005 02:49
EXPORT ENSIGHT TRANSIENT Aris FLUENT 0 December 12, 2004 12:50
ensight for KIVA Sasidhar EnSight 2 November 10, 2004 13:46
