-   FloEFD, FloWorks & FloTHERM (http://www.cfd-online.com/Forums/floefd-floworks-flotherm/)
-   -   Cd Drag , CdA (http://www.cfd-online.com/Forums/floefd-floworks-flotherm/112015-cd-drag-cda.html)
caslor January 20, 2013 09:16
Cd Drag , CdA
Hi i would like to ask some theoritical questions
i want to find cd and cda in solidworks
I have an object moving to Z axis in air
i place speed of air - 40m/s
from the type cd = 2Fd / p* V^2 * A
we know :
p = (normal density of air )
v = 40 m/sec
fd = If i place in solidworks at global goals to calculate the normal force in Z axis ... is that the Drag force and so the Fd ??
A = the front aria of my object (cross section area)
Engr.RZA February 4, 2013 04:29
Use standard relationship for drag:
Drag Force Coefficient = CD =
\sumFz (in your case) / [1/2 x \rho x V^{2}]
Here
\sumFz = Total Drag Force
Boris_M February 18, 2013 12:03
Hi caslor,
Normal Force is not the drag force, it is the force normal to the surface only. The normal force is basically the force of the pressure on the surface but not the force due to friction. For drag you should use "Force" and in your case the component of the force in the direction of your flow.
Boris
