Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Pressure distribution into Mechanica
Old   September 10, 2013, 01:40
Default Pressure distribution into Mechanica
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Do we need a special installation of ProMechanica, for importing a pressure distribution on a surface from FloEFD (for Creo) into ProMechanica?
Thank you for any information
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 16, 2013, 02:41
Disabled
Boris_M will become famous soon enough
Hi Maxime,
no, you shouldn't.
Do you have any troubles applying the pressure distribution?
Boris
Boris_M is offline   Reply With Quote
Old   September 17, 2013, 01:26
-mAx-'s Avatar
Maxime Perelli
Hello Boris,
Now it is ok, I found the option in pressure load's panel
Now I have to play a little bit with this tool, because ProM is asking me the value of the pressure, (but it is supposed to be calculated with FloEFD).
I will run a job with a pressure of 1 Pa to see what FloEFD is exporting exactly ...
From the pressure load panel, I understand I loaded an extern field coefficient and not a true pressure load
anyway, I will digg it
Old   September 17, 2013, 06:31
Disabled
Hi Maxime,
I have a how-to guide for you if you send me your email adress in a private message. Or you can also find it on our SupportNet website.
Regards,
Boris
PS: Grüße aus Frankfurt :-) I saw your german GUI
cavitation model pressure distribution Rahmat Arazgaldy FLUENT 1 May 16, 2012 15:48
Airfoil pressure distribution kanishkpanchal Main CFD Forum 2 December 7, 2009 13:21
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
