Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Vaporising Coolant
Old   April 1, 2014, 03:29
Default Vaporising Coolant
Floris Duyfjes
Floris is on a distinguished road
I'm working on a little challenge ():
I wish to simulate the mixing of a fluid with a coolant. As we already know from the client; a part of the coolant actualy vaporises partially and gets mixed as little gas bubbles.
I understand these bubbles are just a bit too much to be visualised by the software. But, still the compress-ability of the mixture changes drastically.
So, I wonder, is there a way to simulate this change in compress-ability?
Any advise would be most welcome
Cheers Floris
Floris is offline   Reply With Quote
Old   April 18, 2014, 05:50
Tim Shute
tim_shute is on a distinguished road
Without question, such a bi-phase flow problem is a challenge for SW flow simulation. ANSYS may help you out.
tim_shute is offline   Reply With Quote
Old   April 20, 2014, 11:57
Disabled
Boris_M will become famous soon enough
Hi Floris,
yes, bubbles and foam like appearences are not possible with FloEFD but you can define compressible liquids in FloEFD if you know the properties of it. You can create them in the engineering database under compressible liquids. If that corresponds to the reality with bubbles I cannot tell.
Regards,
Boris
Boris_M is offline   Reply With Quote
high LHTC values in Coolant jacket analysis rcm STAR-CCM+ 7 January 15, 2011 00:21
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 09:04
Cooling of a turbine blade - Injection of coolant PA Main CFD Forum 0 June 16, 2007 07:19
Input for CHT analysis of coolant jacket Farhath FLUENT 0 July 3, 2006 07:04
Coolant flow analysis - IC engine Frank FLUENT 2 May 19, 2002 15:59
