-   FloEFD, FloWorks & FloTHERM (http://www.cfd-online.com/Forums/floefd-floworks-flotherm/)
-   -   Specifying turbulence parameters for natural convection on vertical flat plate (http://www.cfd-online.com/Forums/floefd-floworks-flotherm/127498-specifying-turbulence-parameters-natural-convection-vertical-flat-plate.html)
abu250feldman December 12, 2013 13:22
Hi all,
I am simulating natural convection from vertical wall. the fluid is water.
I know this is very easy to calculate using simple correlations, however for some reason, I got more then 50% error between the manually calculated and CFD results. I have a wall 2.4 m high with Tinf=10 C and DT of 20 C. The Ra_L is turbulent (equal 5e12). I used two correlations for turbulent flow 1. 0.1*Ra^1/3 and 2. (0.825+0.387*Ra^(1/6)...)^2 (churchill and cho). I got h=450 W/m^K and h=534 W/m^K respectively.
In the CFD however, I get 340 W/m^K when using the "turbulence intensity and length" with default parameters. when I change to "Turbulence energy and dissipation" I get 400 W/m^K. Both results are way off...
I can get different results if I change the parameters but its is difficult to know the correct values.
My question is (finally): which model is better for natural convection (my case) and does anyone (Boris maybe?) has some guidelines on specifying the correct turbulence parameters?
Thanks in advance
Boris_M December 20, 2013 10:01
Hi Yoav,
this is a validation case the developers are considering with each version before shipment.
In fact I have the project setup and can send you the results if you provide me with your email address in a private message.
Regards and happy holidays,
Boris
enayath May 5, 2014 13:42
Boris,
Could you please share this information with me also?
I sent my email address in a private message.
Thank you,
Hooman
