June 12, 2014, 03:42 |
Flow EFD type of k-e
Mark Keown
Is Flow EFD / Flow Simulation using the "revised k-e" or the "standard k-e" turbulence solver?
Application is building aerodynamics and it is recommended to use the "revised". Ref: CFD Simulation for pedestrian and wind comfort and wind safety in urban areas: B. Blocken. |
June 23, 2014, 00:48 |
Disabled
Rep Power: 23 |
Hi Mark,
FloEFD is using a modified k-e model. What exactly are you trying to simulate? I know FloEFD is used in HVAC applications but they range from HVAC ducts and units to room simulation. Boris |
June 23, 2014, 01:01 |
Mark Keown
Thanks for the reply.
In this application working on building aerodynamics and was looking at a 'best practice guide' that specified the k-e type. Building aerodynamics is the flow of air around the outside of buildings and determining if the building design creates air velocities that are hazardous. |
June 23, 2014, 02:53 |
Disabled
Rep Power: 23 |
Ok, I understand. I don't think that should be a problem for FloEFD.
Boris |
building aerodynamics, flow sim, turbulence |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
BuoyantBoussinesqPimpleFoam Modification for LES Capability | simonsg | OpenFOAM | 11 | July 20, 2017 11:31 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
Error during initialization of "rhoSimpleFoam" | kornickel | OpenFOAM Running, Solving & CFD | 8 | September 17, 2013 05:37 |
