Specifying turbulence parameters for natural convection on vertical flat plate |
December 12, 2013, 12:22 |
Yoav
Rep Power: 15 |
Hi all,
I am simulating natural convection from vertical wall. the fluid is water. I know this is very easy to calculate using simple correlations, however for some reason, I got more then 50% error between the manually calculated and CFD results. I have a wall 2.4 m high with Tinf=10 C and DT of 20 C. The Ra_L is turbulent (equal 5e12). I used two correlations for turbulent flow 1. 0.1*Ra^1/3 and 2. (0.825+0.387*Ra^(1/6)...)^2 (churchill and cho). I got h=450 W/m^K and h=534 W/m^K respectively. In the CFD however, I get 340 W/m^K when using the "turbulence intensity and length" with default parameters. when I change to "Turbulence energy and dissipation" I get 400 W/m^K. Both results are way off... I can get different results if I change the parameters but its is difficult to know the correct values. My question is (finally): which model is better for natural convection (my case) and does anyone (Boris maybe?) has some guidelines on specifying the correct turbulence parameters? Thanks in advance |
December 20, 2013, 09:01 |
Disabled
Rep Power: 23 |
Hi Yoav,
this is a validation case the developers are considering with each version before shipment. In fact I have the project setup and can send you the results if you provide me with your email address in a private message. Regards and happy holidays, Boris |
May 5, 2014, 13:42 |
Joe
Rep Power: 14 |
Boris,
Could you please share this information with me also? I sent my email address in a private message. Thank you, Hooman Last edited by enayath; May 23, 2014 at 11:40. |
natural convection, turbulence parameters |
drag of flat plate with cavity | Far | FLUENT | 0 | May 18, 2010 04:57 |
DNS for Impinging Jet on a Flat Plate | Chandra Shekhar | Main CFD Forum | 3 | January 18, 2010 05:03 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Seperated Flow and Turbulence modelling flat plate | Simon Mizzi | Main CFD Forum | 1 | December 16, 2003 01:26 |
Turbulence dead? well... can somebody help me with a flat plate meanwhile? | Javier | Main CFD Forum | 2 | May 23, 2000 04:41 |
