Home > Forums > FloEFD, FloWorks & FloTHERM
floefd boundary
Old   August 29, 2014, 22:58
Default floefd boundary
qinxiao
henduocha is on a distinguished road
When i select four surface loading 3m/s at the same time,and i select the surface respectlly four times loading 3m/s ,what's the difference?
henduocha is offline   Reply With Quote
Old   September 21, 2014, 16:41
Boris Marovic
Boris_M will become famous soon enough
Hi Henduocha,
I assume you mean that you apply a single inlet velocity boundary condition or you apply four seperate inlet velocity boundary conditions on these four surfaces.
If you look at the boundary condition reference coordinate system you will see that for one surface the reference system is the one of the surface you selected if it is a planar surface and the global coordinate system if it is a non-planar surface. In case you select a planar surface, the reference system changes to the global coordinate system as soon as you select the next surface. So in case you want to define a specific direction it becomes important to define the coordinate system for the correct definition of the direction.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Thread Tools
Trackbacks are On
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 05:07
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
