Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Simple steam ball valve
Old   February 26, 2015, 05:06
Default Simple steam ball valve
Jakub
fazolex is on a distinguished road
Hello FloEFD users
I am writing in order to help. I would like to make CFD simulation of simple ball valve. The medium is a steam.
I would like to simulate flow at 100°C which corresponds with the pressure +- 0.1Mpa. (according to thermomechanical tables).
Mass flow rate: m=0.001329kg/s
Could anyone help me with setting of boundary conditions and other parameters to get relevant results ? Because setting the mass flow as a inlet and static pressure as a outlet seems to be strange.
Thank you very much
fazolex is offline   Reply With Quote
Old   February 26, 2015, 19:51
will321321 is on a distinguished road
Hi fazolex,
Can you elaborate more on what went wrong?
Is there a warning message under info when running the simulation?
Also looking at the picture you provided it seems you made "mass-flow as Outlet" and "pressure Opening"(not pressure outlet) at the other end.
will321321 is offline   Reply With Quote
Old   February 27, 2015, 04:31
Default Steam valve
Jakub
Hello will321321,
The pictures you can see in attachment represents:
-inlet mass flow 0.001329kg/s (steam)
-pressure openings - static pressure.¨
Initial pressure corresponds to thermomechanic table for 100°C = 101325Pa.
I am not sure obout setting of the initial velocity (for X axis). At some tutorials I found "Dependency" configuration which takes into account Re, velocity, viscosity and tube diameter. My question is: Is it needen to be set ?
Btw I ran the simulation but I got several error messages, as you can see in the pictures. I cant evaluate the result of the the Mach speed but the small space around the ball will probably cause problem.
Thank you very much for any advice.
Pictures: http://postimg.org/gallery/12pjq1why/
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
How to simulate valve with pressure BC? Luk FLUENT 8 June 20, 2006 08:06
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
CFD in sports David Howell Main CFD Forum 21 July 12, 1999 06:31
