Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Temperature Dependent Loads
Old   April 15, 2008, 05:52
Default Temperature Dependent Loads
RP
Does Flotherm/Flovent support temperature dependent loads ? Just wondering, as I couldn't find the documentation on it. And I still believe there is a lot of scope for Flotherm Documentation improvent. Just my thoughts!
Old   April 15, 2008, 06:29
Default Re: Temperature Dependent Loads
Robin Bornoff
(not strictly an EFD or FloWorks question but anyway...)
Yes, this can be done by using a Temperature Source Attribute attached to a Source Object. A linear relationship between power dissipation and temperature can be defined in terms of a coefficient and value. Note that the either the coefficient or the value can be made to vary in time as part of a transient simulation.
Searching for "source option" in our html documentation will locate the relevant page!
Robin Bornoff
Flomerics Product Manager - Electronics Cooling
Old   April 15, 2008, 06:50
RP
Robin
Thanks for your clarification. I can understand the concept of what you are trying to get. What I am trying to get the workaround is the temperature dependent loads in steady state.
On the source, like for e.g, Can I model the source load based on its centroid temperature, which I don't know initially at the start of the analysis for SS analysis.
Was wondering if thats possible or not.
RP
Old   March 22, 2012, 01:46
mactech001 is on a distinguished road
Is there the same feature in CFX to input temperature dependent body loads too?
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Temperature Dependent Fluid Properties eliwide OpenFOAM Running, Solving & CFD 4 December 15, 2012 19:21
Pressure & Temperature dependent EOS hennas FLUENT 1 October 31, 2011 17:55
Adding a new temperature dependent viscositymodel? dgadensg OpenFOAM Programming & Development 10 May 22, 2010 05:47
Time Dependent Temperature Dependent BC Analysis RP Main CFD Forum 1 March 28, 2008 01:22
