Running Jobs in Batch Model
Hi
Is it possible to run a series of jobs for a given convergence criteria or for a set of iterations. I believe it should be possible. What I am planning to do is to use only ONE license for my jobs and not pick up all the free licenses available on the network. I explored the option as mentioned in the help files, but it picks up ALL the available licenses on the network which I don't want to as it will be a disadvantage to others. Did anyone explore this option, if yes, would you be kind enough to help me out Thanks RP |
Re: Running Jobs in Batch Model
Hi RP,
Is this a Floworks/EFD question, or FLOTHERM/FLOVENT? Thanks, John Parry, Research Manager, Flomerics Ltd. |
Hi John
FLOVENT question. I believe it works the same in Flotherm ! RP |
RP, as this forum is intended to cover just EFD and FloWorks can you please contact your local Flovent support office so that they can field this and any other Flovent questions you might have?
Cheers Robin. |
| All times are GMT -4. The time now is 16:21. |
