Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Running Jobs in Batch Model
Old   April 16, 2008, 04:16
Default Running Jobs in Batch Model
RP
Hi
Is it possible to run a series of jobs for a given convergence criteria or for a set of iterations. I believe it should be possible.
What I am planning to do is to use only ONE license for my jobs and not pick up all the free licenses available on the network.
I explored the option as mentioned in the help files, but it picks up ALL the available licenses on the network which I don't want to as it will be a disadvantage to others.
Did anyone explore this option, if yes, would you be kind enough to help me out
Thanks
RP
Old   April 16, 2008, 05:52
Default Re: Running Jobs in Batch Model
John Parry
Hi RP,
Is this a Floworks/EFD question, or FLOTHERM/FLOVENT?
Thanks,
John Parry, Research Manager, Flomerics Ltd.
Old   April 16, 2008, 07:07
RP
Hi John
FLOVENT question. I believe it works the same in Flotherm !
RP
Old   April 16, 2008, 07:47
Robin Bornoff
RP, as this forum is intended to cover just EFD and FloWorks can you please contact your local Flovent support office so that they can field this and any other Flovent questions you might have?
Cheers Robin.
Running fluent with udf in batch mode zonexo Fluent UDF and Scheme Programming 2 March 10, 2012 07:50
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Running fluent in Batch model P FLUENT 5 April 8, 2005 11:14
help:Implementation of Glass Batch Melting Model chen FLUENT 0 March 7, 2005 20:42
Running 2 CFD jobs on one PC steve podleski Main CFD Forum 17 February 16, 2000 14:40
