Home > Forums > FloEFD, FloWorks & FloTHERM
efd-meshing, bc
Old   August 8, 2008, 06:30
Default efd-meshing, bc
Marescu
Hello everybody, I started with EFD and I stil cannot find where to find some tool to display mesh. I want to see fluid volume of my model with computational mesh in different cut planes etc..(to chcek cell density in boundary layer and some critical places etc). I also found out that there is some convergence problem when I prescribe heat flux(heat loss)BC on walls in model without solid domain (option "heat conduction in solid" turned off) could you give me please a little help in this? thanks a lot M.
Old   August 8, 2008, 07:56
Default Re: efd-meshing, bc
Pranesh
Click Tools, Options. Click Third Party and select EFD.Lab Options tab Click Display mesh
Now use Results(Post-processing) to see the mesh at different sections
Can you please describe your second problem clearly?
Old   August 11, 2008, 09:40
marescu
thanks for advice, regarding boundary condition: heat conduction in solid is switched off, in table defining wall condition is prescribed roughness and heat flux with negative heat flux boundary condition {W.m-2) inlet BC is Total pressure, outlet static pressure. Solving process is stopped after several iteration with error message. When using positive heat flux or wall temperature as b.c. no problems occur.
Thread Tools
Trackbacks are On
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
EFD Meshing White Paper John Parry FloEFD, FloWorks & FloTHERM 0 April 10, 2008 10:20
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
