Home > Forums > FloEFD, FloWorks & FloTHERM
Incorrect area integration.
Old   August 27, 2008, 01:26
Default Incorrect area integration.
Mr Matti Karvonen
Hi.
Has anyone got broblem that FloWorks(=FW for now on) calculates wrong area for surfaces? I guess reason for that might be that FW calculates area of elements, not (real) surfaces.
I tested this also with siple cylinder-shape solid which end area can easily be calculated "by hand" and I got many percent error in results. Is that correct assumption of error reason, and is there any simple way to get correct areas?
Because of error in area all boundary integration results are wrong.
Old   August 30, 2008, 11:43
Default Re: Incorrect area integration.
Nick Sessions
Hello Does the error decrease for the calculated area when you add more cells? Cheers Nick
Old   September 1, 2008, 01:28
Mr Matti Karvonen
I didn't try. I used "Comsol Multi Physics" to solve my problem. That program calculates areas correctly even with very coarse mesh. Maybe it does so because I use tetra/triange mesh which is not available on FW. Only reason I tried to use FW is/was that creatin models is very easy for former solidworks user.
Old   September 15, 2008, 23:13
jeremyli
EFD uses FVM method so you should make you object be meshed well. And EFD can calculate the integration by your mesh.
Thread Tools
Trackbacks are On
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Problem with reference area alfaben STAR-CCM+ 2 September 17, 2011 03:46
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
Integration Points and normal area vectors Bloshchitsyn Vladimir CFX 0 November 26, 2007 08:35
