Pressure loss in PEM cell with different profiles |
April 11, 2009, 16:47 |
Rodrigo
Hello.
I'm a student of Mechanical Engineering and I'm trying to project a PEM cell. Now, I'm studing the influence of different profiles into pressure loss. THE SOFTWARE IS COSMOS FLOWORKS For now, let's focus in a common serpentine. I have working pressure and inlet volume flow rate. I put as bondary conditions, the inlet volume flow in the inner face of inlet cavity and at the outlet cavity, I put static pressure and pressed 'OK'. As inicial conditions, I put the inlet face and accepted the entries. P and T default, defined previous at Wizard. I choose, than, Static Pressure at inlet and outlet surface. And Global Goals velocity and density. I run the solver. Next I put everything in Floworks calculator. I want to know if I can trust in this way of getting pressure loss... Am I right? I believe that it will give me the inlet pressure that I need to choose a pump. Sorry for my english and for the big text... but I'm trying to learn the software by myself. Thanks for everyone... Rodrigo. |
April 14, 2009, 11:00 |
#2 | |
Ivan Dergunov
In FlowSimulation (Formely Cosmos FloWorks) you can define initial conditions in the GeneralSettigs>Initial Conditions. There are possibility to define temperature, pressure and velocity. For some special cases you can use Local initial conditions. For obtaning values of pressure drop you can use Equation Goals={SG Static Pressure Inlet} - {SG Static Pressure Outlet}. |
floworks pressure drop |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 15:38 |
Pressure loss in a combustor | Anand | Main CFD Forum | 0 | April 28, 2003 10:33 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Pressure at the surfaces of a cell | Gao | Main CFD Forum | 6 | January 8, 2001 20:58 |
