-   FloEFD, FloWorks & FloTHERM (http://www.cfd-online.com/Forums/floefd-floworks-flotherm/)
-   -   Non-uniform heat transfer coefficient in Flotherm (http://www.cfd-online.com/Forums/floefd-floworks-flotherm/65791-non-uniform-heat-transfer-coefficient-flotherm.html)
bighead June 25, 2009 21:01
Hi all, just wanna know if its possible to have a non-uniform heat transfer coefficient in Flotherm ?
RobinB June 26, 2009 07:39
Non-uniform is space? Not directly no. A series of HTC can be defined via a number of cutout objects that externally abut the solution domain. These can be defined manually or be created automatically from another model when you use the 'Zoom-in' functionality.
bighead June 26, 2009 15:39
I tried the first option and it work generally fine, except for the postprocessing whereby the cutouts had temperatures of the ambient/global. When I posted the question, I was thinking more of writing a general function of HTC=f(x,y) at the low z. But since the first option solved the problem, I shall lived with it. Thxs for your help Robin.
