Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Physical correlation to FloWorks for air ducting
Old   July 8, 2008, 19:35
Default Physical correlation to FloWorks for air ducting
Matt Quinn
My primary interest has been using FloWorks to improve the flow rate of air through automotive intake systems (filter housing, filter, intake tubes.) While my goal of having the simulation show whether or not a design iteration would be superior relative to the last seemed modest, it has not been so easy.
I prefer to use FloWorks to simulate the design prior to making a rapid prototype. While using FloWorks for the past year or so I have had cases where the simulation indicated that CAD model A was surely better (less pressure drop for a given flow rate) than model B, but in making rapid prototypes of each this was not true. Sometimes the opposite is actually true, B noticeably better than A in the physical test, which means our simulation tool actually sent us in the wrong direction and lengthed development time!
In exploring the cause for this, I am focusing on the knowledge that often the situation exists where the flow outlet has non-uniform pressure and velocity. Also, each design iteration will affect these pressure and velocity profiles. Therefore, the boundary conditions are never the same at the outlet. Suspecting that the boundary conditions must be identical to compare iterations, I am setting out to build geometry in the model to baffle and then diffuse the air at the outlet, so that the pressure is uniform (.1% delta between min and max value.)
So my question is do others add geometry to their outlets to affect the boundary conditions in this way? What considerations or pitfalls are there in this technique?
Old   July 18, 2008, 11:28
Default Re: Physical correlation to FloWorks for air ducti
RGB
Perhaps this is not a boundary condition issue.
It would be interesting to run these in a different CFD solver to see whether it showed the same trend as EFD.Lab.
Old   December 14, 2009, 10:58
JohnParry's Avatar
John Parry
JohnParry is on a distinguished road
Looks like an old post, but I would say this is most likely a boundary condition issue. I've come across similar issues in electronics cooling applications, where to get the correct flow through the box it's been necessary to include the environment outside the box in the analysis, for example if an intake vent is very close to the floor, as a fixed stagnation pressure boundary condition assumes that flow approaches normal to the boundary, whereas in reality it does not. So, my advice would be to first extend the model to capture the way the flow approaches the intake and then judge.
JohnParry is offline   Reply With Quote
[Gmsh] Version 20 of the bmshb file format to FOAM converter 7islands OpenFOAM Meshing & Mesh Conversion 36 February 9, 2019 22:47
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Cross Axial Rotation problems with FloWorks jacobjb FloEFD, FloWorks & FloTHERM 2 March 8, 2010 14:20
Physical meaning of this velocity pressure correlation? huijingmm Main CFD Forum 0 January 22, 2010 00:20
