Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
velocity profile in floworks
Old   August 18, 2009, 04:57
Default velocity profile in floworks
Carlos
crzbur is on a distinguished road
hi,
i am running an external flow analysis for a flat plate and would like to set the velocity profile as the power law equation, which describes the mean wind profile of the atmoshperic boundary layer.
Is that using the dependency button? If so, is it only typing up the equation? How can I make it dependent of the height z (height measured from the bottom of my computational domain)?
Thanks.
crzbur is offline   Reply With Quote
Old   January 28, 2010, 06:02
Mika
Nika is on a distinguished road
In a dependency forumlation you can only use known parameters, either from the flow or from the geometry.
So if you want to use a height, try to create it in SolidWorks (as a sketch or even as a coordinate system.
Nika is offline   Reply With Quote
Old   March 3, 2010, 20:27
MuratSuer is on a distinguished road
In my idea you can generate a formula with using Excel for velocity profile depends on height then you can use this formula with dependecy type
If you want to use table option it takes long time to fill in(no export option as txt or excel file)
MuratSuer is offline   Reply With Quote
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 06:25
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 03:44
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 19:09
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
