Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Boundary Conditions: Non constant flow pattern / temperature profil
Old   August 16, 2010, 09:06
Default Boundary Conditions: Non constant flow pattern / temperature profil
Janshi is on a distinguished road
First at all, please allow me to introduce myself. My name is Shichun and I´m working on my Mastertheses.
Currently I´m looking for a possibility to simulate the Mixture of two Gasflows.
I have a Combustion in a Tube. Through researches with Thermocouples I know the temperature profil from my flue gas.
The flue gas shall enter an "object", where it is mixed with Air.
It seems that I have a basic problem.
I have to define the boundary conditions at the Inlet for the "object".
So how can I tell FLoEFD that I have a non constant flow pattern/velocity profile and temperature profil of my flue gas at the inlet of my "object"?
Thanks,
Shichun
Janshi is offline   Reply With Quote
Old   September 1, 2010, 02:56
Disabled
Boris_M will become famous soon enough
Hi Shichun,
I hope it's not too late already but here is the way to do it.
In the boundary settings for pressure or flow rates you can vary the pressure and flow rates either over time or over a coordinate such as x, y, z or the radius etc. You cannot define a distribution on a surface in two coordinates, just one f(x) or f(y) etc. is possible.
You can define it as a grah like the fully developed flow profile of a pipe with f(r) or you can define it with a function. The same goes for transient analysis f(t) or as a pulsation defined with a function such as 5*sin(3*Pi*t) or something like that.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Pulsatile Flow Boundary Conditions Lior FLUENT 3 April 20, 2014 07:26
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Constant temperature boundary Ananta Phoenics 3 June 5, 2008 09:24
Internal flow simulation boundary conditions Kishore FLUENT 1 July 10, 2007 11:42
