[Sponsors] | |||||
Gene G
Rep Power: 0 ![]() |
Hello, I am using EFDLAB 8. After bringing my model (STEP) and running Geometry check, I am getting good numbers (different from zero). After applying all the conditions and assigning all the parameters, system refuses to run my analysis and running geometry check again gives me a zero fluid volume.
I checking interferences, I found none. Any leads? Thanks |
Boris Marovic
Rep Power: 4 ![]() |
Hi Gene,
if you run ther check geometry before you ran the wizard to setup a project then you might have used it for external analysis if there was a gap somewhere and if you then define internal analysis in the wizard then you won't find a fluid volume if there is a gap so the model is not water tight. Try to switch from internal back to external and see if you find a fluid volume. This is a very good indicator to distinguish between invalid contacts and a not water tight model. If you have invalid contact, neither internal nor external check will find a fluid volume. If there is a gap somewhere in you model you will find a fluid volume only in an external case as the model is not water tight for internal case it cannot find a enclosed cavity. I hope this helps, Boris |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
| Water subcooled boiling | Attesz | CFX | 6 | June 9, 2011 08:11 |
| There is no fluid volume in the project | Giron | FloEFD, FloWorks & FloTHERM | 4 | June 12, 2009 17:05 |
| How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
| fluid hot volume in fluid cold volume | zahid | FLUENT | 4 | June 1, 2002 09:11 |
