Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
how to use contact resistance model in floEFD
Old   July 8, 2011, 03:53
Default how to use contact resistance model in floEFD
eggliang is on a distinguished road
I am tring to learn how to use contact resistance in floEFD software. I have done several cases to verify if this model works. but the result makes me a little bit disappointed. I applied the contact resistance between two contacting surfaces, but from the result, there seems to be no temperature drop btw these two surface. thus, it looks unbelivable.
is there any guys have experence on this? tell me how set this contact resistance to make it work..
any feedback is pretty appreciated...
eggliang is offline   Reply With Quote
Old   July 15, 2011, 14:53
Gene G
GeneG is on a distinguished road
Select contact resistant surface and assign : User Defined → eGRAF: Spreadershield HT-1205
(Th. Res. = 3.2e-5 C^2/W) as an example
GeneG is offline   Reply With Quote
Old   July 21, 2011, 01:31
great.
I re-do the simulation with a much more simple model and applied the contact resistance value to it. the result told that this resistance did work now. interesting results...
but previously i applied this resistance in my LED LAMP model btw two solid contacting surface, no temperature found..
Old   August 1, 2011, 08:07
Disabled
Boris_M will become famous soon enough
Hi eggliang,
have you tried it again in the more complex model? Did it work now?
If not please send the model to the support as they can check if there is any other issue that prevents it to work of if there might be a bug of some kind.
Usually if it works in general on a simple case then it's related to the geometry as the more complex case could contain a more complex geometry that could cause this issue for some reason.
I've seen cases where the geometry looks just perfect on the screen but something is bad in the CAD definition.
Regards,
Boris
Boris_M is offline   Reply With Quote
Old   August 5, 2011, 00:36
dear Boris
sorry, I have not studies the case of more complex geometry for busing working recently. anyway, I think the contact resistance is a useful function designed for thermal designers. I don't know if you have some progress on this issue?
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
