Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Blockage in pipe ( using solidwork flow simulation)
Old   December 5, 2011, 12:51
Default Blockage in pipe ( using solidwork flow simulation)
leong june chow
jchow is on a distinguished road
Hi everyone ,
I am doing flow simulation about flow behaviour before the fluid (water) flow through the blockages . The blockages is placed internally in the middle of pipe
Paramater
length of pipe =1m
Inner diameter of pipe = 30mm
thickness =1mm
Type of flow = water
length of the blockage =10mm
Boundary condition
inlet velocity = 1m/s
fully delevoped flow
outlet = static pressure
I wan to analysis the pressure and velocity of the pipe due to change in blockages size.
How to plot the graph to show the pressure and velocity ?
Is it correct according to my setting ?
case 1
blockage size outer diameter =30mm
internal hole -10mm
case 2
blockage size outher diameter =30mm
internal hole =20mm
jchow is offline   Reply With Quote
Old   January 16, 2012, 16:03
Disabled
Boris_M will become famous soon enough
Hello jchow,
Do you want to know how to create a plot such as a cut plot or a xy-Plot or do you want to compare the cases?
If it is the later then currently you will have to note the results such as pressure loss and velocity you are looking for and enter them manually in an Excel table. Or if you know how to program than you can also write a small program that collects the values of the projects automatically and enter them in the table. You can find out more about that if you click on help and select API help.
Regards,
Boris
Boris_M is offline   Reply With Quote
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
Wing lift in Solidwork Flow Simulation brianmcv Main CFD Forum 6 April 11, 2011 08:16
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
FDTD Simulation of flow through tapered pipe Jim Main CFD Forum 3 December 25, 2006 10:56
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
