Home > Forums > Software User Forums > FLOW-3D
question about Nested Grid for two fluids
Old   May 8, 2012, 05:34
Default question about Nested Grid for two fluids
Zeng is on a distinguished road
I started a simple flow example:
rectangular block and make it partly nested
half water (depth=0.3m) and half air
a water flow with constant velocity comes from right boundary, u= 0.1 m/s
the simulation will be easily done if 'one fluid' is chosen, whether 2-d or 3-d. However, if I choose two fluids(water and air), while all the other condition and parameters exactly the same with one fluid situation, the errors will occur.
'convective flux exceeded stability limit' will soon come along. After 2 or 3 of them, excessive convection failures make calculation terminated. And only 4e-09 second is calculated.
I'm stuck....I need advice. Thank you!
Zeng is offline   Reply With Quote
Old   May 10, 2012, 21:10
michael barkhudarov
MuxaB is on a distinguished road
Is there an outlet at one of the mesh boundaries? For two fluids, if there is an inflow, there also must be an outflow.
MuxaB is offline   Reply With Quote
Old   May 10, 2012, 21:55
yes, there is an outlet boundary~
the mesh is as followed:
block1
x:0~1.0, nxcelt=50, y:0~0.1, nycelt=5, z:0~0.5,nzcelt=25 ;
block2
x:0.5~0.8,nxcelt=30, y:0.02~0.08, nycelt=6, z:0.1~0.4, nzcelt=30 ;
Boundaries of block1 are:
right: V , left: O , front and back: S , bottom:W , top:P ;
for block2 they are all Symmetry
Old   May 10, 2012, 23:24
michael barkhudarov
hmm. is air modeled as compressible fluid?
Old   May 11, 2012, 00:00
The flow mode is chosen as incompressible, so both two fluids are calculated as incompressible, right?
I thought that inter-block boundary type coefficient(alphamb) might affect, so I changed it from default to 0.5 or 1.0, but still didn't work....
Old   May 19, 2012, 02:08
michael barkhudarov
It is hard to figure out without seeing the problem. Have any ideas yourself?
Old   May 27, 2012, 09:50
Mahdiar Farhoudi
mf_emp is on a distinguished road
That is exactly my problem too!
did you get what to do?
you can also check out:
Help > CUSTOM TUTORIALS > Hydraulics Tutorial > Variation: Run as a Two-Fluid Problem
mf_emp is offline   Reply With Quote
nested block, two fluids
"grid points" or "grid interface" ztdep Main CFD Forum 1 June 6, 2007 15:00
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 18:18
grid spacing question clifford bradford Main CFD Forum 5 November 10, 1999 18:40
A question about elliptic grid generation A.Rajani Kumar Main CFD Forum 3 March 12, 1999 09:33
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 22:26
