Home > Forums > Software User Forums > FLOW-3D
Greetings from Australia
Like Tree1Likes
  • 1 Post By Karen
Old   September 30, 2008, 20:45
Default Greetings from Australia
Karen
Hello from Australia to all the Flow-3D users out there! It's great to see we finally have a 'home' at CFD Online.
By way of introduction: I have been using Flow-3D for about 7.5 years now, mostly for open channel flow in hydraulic structures (spillways, intakes, outfalls, pump stations, fish passages etc), and I've also used it for the occasional blast analysis or ventilation study.
Looking forward to being a part of the forum!
Cheers,
Karen Riddette (Senior Engineer / Analyst)
WorleyParsons Advanced Analysis, Sydney, Australia
chostov likes this.
Old   October 1, 2008, 06:02
Default Re: Greetings from Australia
ali etesam
Dear Karen Riddette I am ali etesam.I want to model an Ogee spillway 3D with FLOW-3D ver8.2. But How can do that? Please help me. Thanks
Best regards
Old   October 1, 2008, 20:44
Karen
Hi Ali,
You should start by looking at the example model of 'Flow over a weir' to understand how the boundaries and initial conditions should be set up.
Then you need to modify the example to include your Ogee crest geometry. I usually create a 3D STL file using third-party modelling software and import it into Flow-3D.
Cheers, Karen
Ps - you might want to upgrade your software too, there have been a lot of improvements since v8.2!
Old   October 2, 2008, 04:47
ali etesam
Hi Karen I know that at firs step should study exampels i did that. Thank you very much.
Old   June 28, 2016, 00:54
Jack Wu
Jack Wu is on a distinguished road
My research is pump stations. I want to put pump in the simulation, and i was using fan and impeller mode but the flow behind the impeller was not ture. would you sent me some cases about this model? thank you very much. i do appreciate it
my email 403761912@qq.com
Jack Wu is offline   Reply With Quote
OpenFOAM training Sydney, Australia and Houston, Texas, Spring 2011 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 February 16, 2011 15:33
OpenCFD and SGI take OpenFOAM training to Australia OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 February 6, 2009 13:39
OpenFOAM in Australia rmorgans OpenFOAM 0 May 22, 2007 23:53
cfd summer courses in australia clhona Main CFD Forum 0 May 4, 2006 06:48
