Home > Forums > Software User Forums > FLOW-3D
Hybrid Shallow Water/3D Flow Model
Like Tree2Likes
  • 1 Post By ara_nersesian
  • 1 Post By JBurnham
Old   September 17, 2012, 04:38
Default Hybrid Shallow Water/3D Flow Model
Ham Ta
Hamed&honey is on a distinguished road
Hi everybody,
which version of Flow-3D support (Hybrid Shallow Water/3D Flow Model) model?
I have problem to setup physics and meshing
best regards
Hamed&honey is offline   Reply With Quote
Old   September 17, 2012, 08:11
ara
ara_nersesian is on a distinguished road
hi
in FLOW-3D Version 10.0 you can do what you want in shallow 3d modling
it have i sample which showing a reiver with a shallow water runing
i am new in flow-3d i made my mesh and geometries plus a horizental pump i want to cheange direction if you knew the answer i will be glad with your repplay
Hamed&honey likes this.
ara_nersesian is offline   Reply With Quote
Old   September 18, 2012, 12:00
Jeff Burnham
JBurnham is on a distinguished road
Combining 3-D mesh blocks (full 3-D solution) with Shallow Water mesh blocks (2-D depth-averaged solution) will be available in v10.1, which is due out later this year. Until then, you must use either the depth-averaged shallow water model OR the full 3-D solution, but not both.
JBurnham is offline   Reply With Quote
Old   September 19, 2012, 02:13
Ham Ta
Thank you body for your kind attention,
Now I know what should I do
Old   September 19, 2012, 02:21
Ham Ta
Old   September 19, 2012, 02:27
Ham Ta
What model should I use for a 2D flow around a wing? Sarin FLUENT 0 November 12, 2011 21:46
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
Coupling Radiation with Flow model tongx051 FLUENT 0 October 22, 2011 16:03
lenght and number of nodes for an orifice meter flow problem - k-eps model fofo FLUENT 0 November 15, 2009 03:49
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 01:51
