Home > Forums > Software User Forums > FLOW-3D
Two Fluids Flow
Old   August 8, 2011, 02:23
Default Two Fluids Flow
Y_G
yaser geraili
Y_G is on a distinguished road
Hi everybody
I'm trying to model a flip-bucket with two fluids (air and water). simulation solves the flow on chute but when the flow reaches to the lip of the flip-bucket, simulation can not solve the pressure (pressure iteration did not converge at ITMAX). I've totally tried lot's of conditions for example VOF method, different mesh size, turbulence model, number of iteration, time step, but didn't work. does anybody have an Idea?
thanks.
Y_G is offline   Reply With Quote
Old   September 19, 2011, 05:40
Niraj Shah
nirajshah85 is on a distinguished road
Hello Yaser,
I think you can model a Flip-bucket with one fluid free surface flow in F3D. You can use the air entrainment model alongwith the simulation to check on the air entrained in the water.
If for the simulation you believe that there is a large amount of air entrainment to have density change then you can also activate the density model and in case if you are also modelling the downstream area then you can also have the drift flux model activated to allow the trapped/entrained air to escape to the surface.
nirajshah85 is offline   Reply With Quote
Old   November 13, 2012, 07:35
Mahdiar Farhoudi
mf_emp is on a distinguished road
Hi, did you find what was the problem??
I had this problem too!
I also tried density evaluation and drift flux model but no correct answers!!
I'm working on U-shaped spillway.
mf_emp is offline   Reply With Quote
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
mixinf fluids in solidworks flow simulation 2011 robantwerpen Main CFD Forum 0 January 6, 2011 03:53
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
