Home > Forums > Software User Forums > FLOW-3D
Multiplier for dynamically adjusted convergence criterion
Old   September 26, 2012, 11:06
Default Multiplier for dynamically adjusted convergence criterion
buddler is on a distinguished road
I've got a question to the "Multiplier for dynamically adjusted convergence criterion", normally it is set to 1,0. Can someone tell which values it should be set to to get accurate results? Is the standard epsadj=1.0 enough or should there be a value less then 1.0 ?
Sorry in this case i really don't have any idea, normally i just didn't change anything at this vallue, but i got a simulation where the epsadj was set to 0.01 and therefere the calculation time for that simulation is much longer than for others, so i just wanted to know if i simply can set this value to 1.0 without getting false results?
buddler is offline   Reply With Quote
Old   September 28, 2012, 12:55
dmilano is on a distinguished road
Most of the time the default setting is adequate. You would really only want to reduce this value if the pressure/velocity solution looks unphysical and the pressure solution convergence is the suspected cause.
dmilano is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
convergence criterion Dominique FLUENT 5 November 24, 2006 02:36
Setting convergence criterion Vidya FLUENT 5 August 6, 2006 16:46
