-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Favorize (http://www.cfd-online.com/Forums/flow-3d/107847-favorize.html)
Hamed&honey October 8, 2012 04:23
Favorize
1 Attachment(s)
Hi everybody,
See the attached file, I have a sloped solid body, when I favorize the model with inefficient mesh size. I see the stepped slope and itís not good, I know about FAVOR action, but how I can improve my model (except increasing mesh).
Thanks
mderosca October 8, 2012 07:06
Favor
As I know is just visualization. Favor algorithm creates a plane in each cell to determinate the surfaces, but when makes the render don't shown the planes and apears littles steps.
So run the model and you will see no problems.
Hamed&honey October 8, 2012 10:16
dear mderosca
I think your answer is not correct, after I run the simulation still have problems, please check it and tell me if i wrong.
so many thanks
robert_cfd October 9, 2012 03:29
For such a simple case you can make the geometry horizontal and change the gravity instead. Just a workaround for simple geometries, otherwise gridrefinement and a simulation restart.
Hamed&honey October 9, 2012 05:04
dear robert_cfd,
thank you for answer
But my model is so complicated (Ogee spillway with chute)
even use 2 million volume still I have step in my model that is bad influence on my real model.
robert_cfd October 9, 2012 07:12
Ok, I see. Is the spillway straight? Just the spillway, not the whole powerplant? When I look at your attached picture, you might also use symmetry or even just one cell in width (quasi 2D). Then you can use more cells without loosing time.
Hamed&honey October 9, 2012 17:37
1 Attachment(s)
I have 3D model and you can see the whole 3d solid in attached file.
with 2 million mesh still I have problem,
robert_cfd October 10, 2012 08:16
For me it looks like you could test
-how it works with one cell in y direction
-or rotate the geometry around y axis till the flat main part is horizontal, using the angle for calculation of the x and z component of the new gravity field. Then you only have to take care of the in- and outflow area with a finer grid.
Davahue October 17, 2012 04:49
Dear Hammed,
in my experience, you would be impressed with results. Maybe you don't expect such good ones.. I would launch some 2D simulations only to prove it.
But maybe you have tried yet. If you are asking for something like unstructures body fitted meshes you won't find it. Just give it a chance :o
Hamed&honey October 17, 2012 05:39
dear Davahue
I have investigating cavitation on spillway chute, and we know that the rough surface can be increase cavitation index, I have straight slope in real, but stepped slope in model. is this ok? I think its not going to accurate result. am I wrong?
Thanks
Davahue October 17, 2012 10:47
You are wright,
but I suppose you are using a RANS model, so the way it faces the boundary layer has nothing to do with what you are thinking (from a classical hydraulical point of view). I would recommend you to read about wall functions in David Wilcox's (or others) or the FlowScience Technical Note about Roughness. The aproximation all RANS turbulence models do about the surface roughness is very important, if you take it into account, you won't be so demanding on surface resolution. I mean, for a numerical model of N-S equations to reflect exact gradients nearby the surface would need thousands of cells in the boundary layer. If you have not that resolution, that artificial roughness created by FAVOR, in my opinion, is not afecting definitively the main flow because the model doesn't catch it.
I'm not an expert, but i'm sure Michael Barkhudarov or many other experts in this forum could tell you if i'm wright or wrong or how to face your problem better. Anyway, try it and compare the results with experimental data.
Hope it helps,
D.
QUOTE=Hamed&honey;387049]dear Davahue
Thanks[/QUOTE]
Hamed&honey October 17, 2012 11:48
dear Davahue
I think you are an expert :)
in fact, basic problem is about velocity,
Those steps are very effective on velocity
cause to reduction.
I compare with experimental model.
velocity at the jump location
Exp=25 m/s
CFD=20 m/s
