November 2, 2012, 13:20 |
Volume source rate
max
I have a simple plot setting with sloping surface for Shallow water modeling. The 4 faces (x-min, x-max, y-min, z-min) are set wall boundary and upper (z-max) is set pressure boundary and y-max is set outflow boundary. I want to apply volume source rate uniformly (rainfall) only to open upper boundary. But it seems FLOW-3D accounts outflow boundary into open boundary too. How can I apply volume source rate uniformly only to upper boundary which is sloping surface? Thank you, |
outflow boundary, shallow water equations, sloping surface, source rainfall |
how to calculate the reversed volume flow rate in an certain iso-surface? | coolliuyinli | FLUENT | 2 | September 4, 2012 01:33 |
Please check out my parallelized udf code | aleisia | Fluent UDF and Scheme Programming | 0 | June 10, 2011 16:16 |
URGENT: How to set fixed volume rate in a air volume? | SolarX | FLUENT | 1 | September 17, 2010 10:25 |
average volume flow rate | carno | FLUENT | 0 | April 12, 2007 06:37 |
