Mass/momentum source at number of locations
Hi
I am trying to model simple 2D flow simulation where the mass/momentum source is applied through number of points. Is there a easy way to input these large number of sources (around 500) without manually adding mass/momentum source for each location? I would highly appreciate any comments. Many thanks in advance. Max |
I assume you are not using the latest version. In that case, I suggest using a spreadsheet program with the '=concatenate("xxx",X1," ",X2) type syntax to generate a column of text entries for the prepin file directly. Refer to the User Manual for the variables and syntax of the prepin file.
| All times are GMT -4. The time now is 03:56. |
