how to model thermal bubble inkjet?
HI everyone,
I want to model thermal bubble inkjet. i don't know how to heat the liquids and generate bubble. I have used the model: bubble and phase change,heat transfer, surface tension , viscosity and turbulence. In the boundary condition i use wall ->thermal information->power:5e8, but it doesn't work .Only a small region of liquid near the wall increase temperature and doesn't have any bubble or phase change. The liquid i use is water(CGS unit at 20C) In the phase change, I input the data below: saturation pressure:1e6 saturation temperature:373 latent heat of vapor:2.257e6 gamma:1.4 accomodation coefficient:0.1 vapor specific heat:6.67e6 exponent temperature:1.182e-4 superheat temperature:0 can somebody teach me how to set the accurate model to run thermal bubble inkjet simulation? best reards Tim |
by the way, my edition is v9.3!
If the water is not warming up, I would suggest checking the thermal property coefficients of the water itself (Fluid 1): liquid specific heat CV1, liquid thermal conductivity CHV1. Also set heat transfer coefficient between wall and fluid HWALL1.
Dear JBurnham,
Thanks for your reply. I still have some questions. (1)Do I need to creat a component as a wall or use the boundary condition setting"wall", what is the difference? (2)"The heat transfer coefficient between wall and fluid " means the heat conduction coefficient of wall or fluid? Or does it have other meaning? Thanks, Best regards Tim |
You can use either a component or a wall-type boundary, it is up to you. The component may be easier to use. The component-to-fluid heat transfer coefficient is described in the User Manual in some detail, including the ways in which FLOW-3D picks a coefficient if one is not defined.
