Home > Forums > Software User Forums > FLOW-3D
simulate the cavity bottom of the offset
Like Tree1Likes
  • 1 Post By flow_CH
Old   April 11, 2013, 00:04
Question simulate the cavity bottom of the offset
FHydro
flow_CH is on a distinguished road
I want to know can flow3d simulate the cavity bottom of the offset? with Increasing or decreasing the air rate into the ramp.
see this pic.(immediately please)
jarrysimon123 likes this.
flow_CH is offline   Reply With Quote
Old   April 12, 2013, 06:46
FHydro
please help.
I mean that can we inject secondary fluid like air into the working mesh in flow3d? ( defining second point for inlet fluid) see attached pic
Old   April 23, 2013, 12:00
Jeff Burnham
JBurnham is on a distinguished road
Yes. You can do that. Create a new hole subcomponent so that the cavity is connected to the z-min boundary. Make the z-min and z-max boundaries pressure-type with fluid fraction = 0 (the pressure is for 'void', that is, air). Turn on bubble/phase-change physics (adiabatic bubbles). Set all pressures (boundary and initial) to absolute (that is, atmospheric pressure = 101325 Pa) and set the boundary above the flow (z-max) to be atmospheric. This is because the adiabatic bubble model uses ideal gas law and so pressure cannot be negative anywhere. Keep using air entrainment physics, preferably with a calibrated entrainment rate coefficient. Vary the pressure at the z-min boundary to change the supply rate to the jet. Good luck.
JBurnham is offline   Reply With Quote
Old   April 26, 2013, 09:32
FHydro
thanks for your reply.
1- why hole subcomponent? i want to simulate all of the spillway in solid.
2- for calibrating the project i have to know negative pressure and the only reason for suction air into the air slot is negative pressure into the cavity and then can flow 3d show the negative pressure? because my friend said me it can't show negative pressure where the water is not exist.
Old   May 21, 2013, 06:45
Thumbs up thnx
Jarry Simon
jarrysimon123 is on a distinguished road
thanx JBurnham
Bkexpress
jarrysimon123 is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
DirectMappedPatchBase, offset and samplePatch Fransje OpenFOAM Bugs 4 May 1, 2013 03:38
chtMultiRegionFoam - offset santoo_cfd OpenFOAM 11 November 1, 2010 15:01
cavity case with different mesh masterfgee OpenFOAM 1 July 21, 2010 11:53
How to simulate a gripper maxroucool ANSYS 3 April 9, 2010 13:37
