-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   FLOW-3D Redhat Lunch problem (http://www.cfd-online.com/Forums/flow-3d/113191-flow-3d-redhat-lunch-problem.html)
BAssem.at February 14, 2013 10:34
I need help.
I have pb whene i am starting to lunching flow3d in redhat after configuration described in documentation, the message error is:
/home/..../v10.0/gui/lib/ifort/liinf.so : no version information avaliable (required by /home/..../flow3d : line 3 : 30454 Erreur de segmentation).
Please help.
Thank's
dmilano February 28, 2013 11:14
You probably need to set LD_LIBRARY_PATH. There is a file called README in the installation directory that gives an explanation and tells you where to point it.
