-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Customization and debugging (http://www.cfd-online.com/Forums/flow-3d/113240-customization-debugging.html)
mediode February 15, 2013 10:33
at present I am making intensive use of the (great:)) customization possibilities in Flow3D. As the amount of code is steadily growing (already passed a couple of thousands lines) , I was wondering if it possible to use an appropiate debugger (to ease life). Customization is not an standalone appliciation and the debugger would have to stick to the process of the GUI somehow.:confused:
Anybody experience or ideas on that?
Best regards
m*
caroladacey March 25, 2013 06:40
Suggest any appropriate way to customize code in flow 3D!:)
huanglin8545 July 22, 2013 05:18
customization
How can I use customization to get droplets and beam energy to simulate the welding process?Thank you.
JBurnham July 29, 2013 17:22
Droplets are already included in FLOW-3D. See the User Manual > Input Variable Summary > Fluid FL > Droplet Sources section of the manual for the necessary input variables.
huanglin8545 August 3, 2013 09:32
I got it.Now I want to simulate the process that droplets impinge onto the substrate of steel, I must consider the surface heat source of the substrate, how can I realize it?Thanks.
