-   FLOW-3D (
-   -   Baffle (
wusuhong March 1, 2013 04:35
I am doing a side weir project, i want to get the flow rate through the weir.
Setting up a baffle is the method, right?
however, how to set up the baffle?
Is there anybody can help me?...Thanks very much.
flow_CH March 1, 2013 05:03
go to meshing and geometry then baffles the right click on baffles then choose add then check define as flux surface then type 1 to porosity in porosity properties. then you can define it on your project in limiters.
wusuhong March 1, 2013 05:07
I did as the these steps before, but the result Q=0, for many times.
Is there any tips when set up the baffle?
flow_CH March 1, 2013 05:14
read flow 3d 's manual.may be you can find it.
