how to define the turbulent kinetic energy and turbulent dissipation rate?
hi,
a problem has occured to me, that is how to define the turbulent kinetic energy and turbulent dissipation rate in mutiphase flow of oil and water. if the inlet velocity is 5m/s and the diameter of the pipe is 70mm. thanks in advance |
Hi i am familiar with multiphase flow but i used only FLUENT code if you want to transfer to FLUENT i can guide you to the steps but with FLOW-3D i have no idea because i m not use it before.
You can find it in website of flow3d. |
