-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Sediment Scour Depth and Sediment Hight (http://www.cfd-online.com/Forums/flow-3d/122034-sediment-scour-depth-sediment-hight.html)
hossein_sml August 10, 2013 15:19
I am using Flow-3d V9.3.2 for simulating scour around cylinder. How can I measure sediment height and Max. scour depth at this version of flow-3d ?
I really need your prompt help.
Thank
Zerit August 19, 2013 08:01
I guess you can get the results from the iso-surface in 3D output or from the text output as "Packed sediment height" or "Packed sediment net height change".
nramin December 31, 2015 03:47
Hi Hossein
you can send the output file in JPG format to the Autocad, then by scaling the dimensions, you can measure the scour depth with high accuracy
