Home > Forums > Software User Forums > FLOW-3D
open area
Old   August 25, 2013, 22:36
Default open area
huanglin
huanglin8545 is on a distinguished road
Hi everyone,
The preprocessor Messages are:
open area mismatch at inter-block boundaries of all blocks
as % of total open area at these mesh boundaries = 2.98507E-01
How can I solve it?Thank you.
huanglin8545 is offline   Reply With Quote
Old   August 27, 2013, 14:35
Jeff Burnham
JBurnham is on a distinguished road
It means that the cell sizes between adjacent blocks are not optimal for resolving the geometry in the same way on either side of the mesh-block interface. Try to make the cells 2:1 across the boundary, and try to use cell sizes and mesh block extents in such a way that the grid lines match exactly between the two mesh blocks.
JBurnham is offline   Reply With Quote
Old   August 28, 2013, 23:27
huanglin
thank you,I got it.
[swak4Foam] Error installing swak4Foam Hisham OpenFOAM Community Contributions 182 February 8, 2024 10:36
Error: Could not open file XX.h for source file YY.C jans OpenFOAM Programming & Development 3 April 30, 2018 11:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Need help on perforated plate with less than 2% open area sosososo1114 FLUENT 9 August 31, 2011 01:33
Storing Surface Area of each cell in a file? Markus Alzon FLUENT 0 June 21, 2007 08:38
