Home > Forums > Software User Forums > FLOW-3D
mass source
Old   November 9, 2013, 15:47
Default mass source
razieh anari
razieh anari is on a distinguished road
I have a question about the " Mass source " in flow 3d.
I want to simulation a tube with a steady flow. the stream entered the vertical pipe & fill the whole pipe section at top . I created the mass source top of the vertical pipe, that the center of mass is on the center of pipe, & the direction is -z .
the mass source is circular and its radius is equal to pipe radius.
but the problem is: after simulation , i saw the mass source filled the half pipe section.
I don't know why? please advise me .Thank you very much.
razieh anari is offline   Reply With Quote
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
