how to get the value of the flow rate in FLOW-3D |
November 11, 2013, 05:16 |
how to obtain the Value of the discharge Q in FLOW-3D
ouni firas
Rep Power: 12 |
DEAR experts.
i'm simulating a rectangular channel with a weir which is placed in the middle of channel. I want to obtain the Value of the discharge Q.knowing that I made the BC of the output channel as outflow . THANKS Last edited by ounifiras; November 11, 2013 at 13:40. |
November 13, 2013, 12:06 |
You'll want to use a baffle defined as a flux surface. This measures quantities that pass through the baffle and reports the results in the Analyze->Probe->General History data
November 13, 2013, 14:35 |
ouni firas
Rep Power: 12 |
thank you
But I have defined the BAFFLE as a flux surface at the end of the channel and I found negative flow rate values, and more when I open the file fluid volume I was surprised by the presence of the volume value for a very short time, before the flow reaches the BAFFLE, I did not find an explanation. thank you for the explanation |
November 14, 2013, 17:32 |
Jeff Burnham
The negative value refers to the baffle orientation relative to the flow. The baffle has a positive and a negative side. For flow magnitude, you can omit the sign when reporting your results. I do not know why you have volumetric flow across the baffle before the front reaches it. Check your boundary conditions, and check to see if a small depth of flow is advancing before the main wave front.
November 14, 2013, 18:24 |
ouni firas
Rep Power: 12 |
thank you greatly for explaining; for the boundary conditions I set Xmin = Pressure; Xmax = Outflow ; Ymin and Ymax = Balanced, for Zmin = pressure with bcz baffle (1) = 1, and Zmax = Balanced, I don 'I did not understand how to change the sign? or change the direction of BAFFLE, is that I can work with absolut values of the value found?
November 15, 2013, 11:21 |
Flowdy
Rep Power: 12 |
mmmmm I´m not sure if this is what you want but... try Analyse->Probe->Mesh dependent history and in the options of "variable names" you would have Volume flow rate of the fluid at a boundary... you can find that in F1 with the name
"Probing Mesh Dependent History to Determine the Flow Rate" cheers |
November 17, 2013, 07:03 |
ouni firas
Rep Power: 12 |
thank you , but Is there a difference between flow rate and volume flow rate ? i want to obtain Q(m3/s). in the endd off channel.
thank youu |
November 17, 2013, 08:29 |
Flowdy
Rep Power: 12 |
Well I was wondering that also. But following the example of the f1 (How Do I Model...? -> Volume Flow Rate (VFR) Boundary Condition) we can say that yes, this is what you need, it is Q and the units are in [m³/s]
If one reads the meanings also, I would say: Flow rate is the amount of something which crosses a surface in a unit of time. But this something could be measure in mass units (kg/s mass flow rate) or in volume units (m³/s volume flow rate). I think that everyone got used to say "flow rate" to "volume flow rate" and this is why we were confused but I think is the same. I would like that someone else confirm what I´m saying (I´m still not sure) |
February 11, 2014, 16:42 |
Rep Power: 12 |
Flowdy You are correct. Volume flow rate and flow rate are the same things.
December 15, 2014, 00:25 |
#10 | |
Yi-An Chen
Rep Power: 11 |
I set a baffle,and defined it as a flux surface "yes". But when I save it ,"defined as a flux surface" will change to "NO" Ican't see the Value of the discharge Q (Volume flow rate) in the Analyze->Probe->General History data Help me, please!! |
December 18, 2014, 12:42 |
#11 |
RoyDaniel
Rep Power: 11 |
Dear Ounifiras..
From you previous discussion, If I am not mistake..hopefully.. , you are trying to get the Outflow discharge, aren't you. I think we have the same case, but for me in the upstream, the BC is a inflow hydrograph ( volume rate). and what I have done is just simple one , in the analyze-> probe-> I check the Xmin boundary fluid 1 volume rate & Xmax boundary fluid 1 volume flow rate, and then after I click render, it showed two hydrograph which are for me they make sense, where the Xmax hydrograph is bit lower that Xmin because the effect of attenuation. I hope you also can solve as I do, but please correct me If I am wrong.. My Best Regards, Roy Daniel |
Periodic channel flow with time dependent mass flow rate | QBeast | FLUENT | 3 | May 10, 2013 13:14 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
Mass Flow Rate Error | jallison | FLUENT | 1 | May 16, 2011 16:22 |
Determine mass flow rate along flow path | Atit Koonsrisuk | CFX | 2 | October 5, 2003 04:47 |
