-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   partical mass source by parqsr.f (http://www.cfd-online.com/Forums/flow-3d/136310-partical-mass-source-parqsr-f.html)
boesendorfer May 26, 2014 12:19
I want to add mass source at a volume rate to the space by subroutine parqsr.f
How can I ask the solver to call it?
I know how to compile and customize common subroutines in Visual studio and model setup module, but what else should I do in the GUI or .prepin editor just for using parqsr.f?
Thanks
____________________________
$xput
iqsr=1,
$parts
remark='!! Mass Momentum Sources',
nvnts=1,
remark='!! Mass Momentum Source 1',
iaqsrp(1)=1,
ivqsrp(1)=1,
npmax=10000,
ipqsr=2,
I just modified the .prepin file as above, but it didn't work. Is there anything else I should add?
everlasting704 January 12, 2015 22:59
May I ask if you solved the problem.I also encountered a similar problem.If you've found the solution, can give me some help Well.thank you in advance.
