Home > Forums > Software User Forums > FLOW-3D
Static friction and force calculations
Old   June 27, 2014, 04:06
Default Static friction and force calculations
frode gimsøy
Zograth is on a distinguished road
I have a boat with force towards a monopile. The tip of the boat is stuck to the monopile while waves are coming towards it. I want to add static friction so the tip of the boat is stuck in all direction until the transverse and vertical frictional force reach a certain amount of force.
Is there any way to set a static friction coefficent? I know there is an option for it in the surface properties for a component, but it doesn't seem to work. I think that's only for fluids against a surface or am I overlooking something?
I am also wondering how to calculate the frictional forces at the tip of the boat.
Any help is much appreciated.
Zograth is offline   Reply With Quote
Old   June 29, 2014, 02:50
Saeid Ahmadvand
Saeid is on a distinguished road
there are 3 different friction coefficient in this software:
1. go to : Model Setup>>Physics>>Viscosity and turbulence : part:"Wall Shear Boundary Conditions" and set "Friction Coefficient".
2.go to: Model Setup>>Meshing and geometry>>Component x>>component properties>>Surface properties>> "and set "Static Friction Coefficient".
3.go to: Model setup>>Physics>>Moving and simple deforming objects>>collision modeling : and set "Coefficient of Friction" (also this can set in: meshing and geometry>component>component properties>collision properties : and set it for just this component)
Saeid is offline   Reply With Quote
Old   June 29, 2014, 02:53
Saeid Ahmadvand
Depending on your model, you can use any of these cases.
impact force (shear stress) by waterjet impingement herozhu Main CFD Forum 0 May 7, 2014 20:39
Get friction force and pressure force Kiffer Main CFD Forum 0 September 7, 2012 21:54
Friction Velocity Pooven OpenFOAM Running, Solving & CFD 0 March 5, 2010 02:15
decreaing pressure force in 2phase model michaelzhang FLUENT 0 February 26, 2010 08:27
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
