Home > Forums > Software User Forums > FLOW-3D
How to calculate drag forces?
Old   October 28, 2014, 13:56
Default How to calculate drag forces?
Oscar
rail118 is on a distinguished road
Good afternnon,
First of all, sorry for my limited knowledge. I've just three days working with Flow3D.
I have a solid in .STL format, and I want to calculate the drag force of this solid, but I can't find the tool to calculate it.
I did some simulations and I calculated the pressure, velocity magnitude... but I don't know how calculate drag forces. I don't know if I have to activate some options in Physics or Meshing&Geometry...
I hope your answers.
Thanks in advance
R
rail118 is offline   Reply With Quote
Old   October 30, 2014, 10:47
aoz
aoz is on a distinguished road
You should select "Pressure and Shear Force" and "Wetted Area" outputs from
Meshing&Geometry>Component Properties>Component # > Output > click them and run simulation,
Then go to Analyze tab,
Analyze > Probe > General history > Select Component1 Fluid Force and render.
aoz is offline   Reply With Quote
Old   October 30, 2014, 12:14
Oscar
Why should I click integrate option? is not drag force= component1 fluid force= pressure+shear ??
If I click only component1 fluid force= pressure+shear wihout any click, the graph becomes constant over time, so I would have the force value, but if I click integrate option, the graph is rising over time.
What is the real value of drag force?
Old   October 30, 2014, 12:45
aoz
Sorry for confusion .
The Pressure Force values are already integrated values over area.
The "integrate" option is for time integral of value.
So,dont use integrate option, use "component1 fluid force" value.
How to calculate and write out transient drag / lift coefficient in OpenFOAM 2.2.1? shuoxue OpenFOAM Running, Solving & CFD 4 November 16, 2023 10:15
Plot drag forces at porous jump boundary condition Shim FLUENT 1 June 5, 2017 04:31
How to calculate and write out transient drag / lift coefficient in OpenFOAM 2.2.1? shuoxue OpenFOAM 1 October 19, 2013 11:51
How can I calculate drag coefficients when there is a blocking object in front hjcaroline FLUENT 0 June 10, 2012 22:49
Lift and Drag Forces around an Aerofoil studentcfd CFX 1 October 29, 2007 17:36
