March 18, 2009, 15:51 |
About subroutine heatfl.F
James Zhong
Rep Power: 17 |
In subroutine heatfl.F, is heatfl1 an array with subscripts i,j,k or a variable? Besides cell index i,j,k, can I use other variables like t, xi(i),yj(j) and zk(k) in this subroutine?
March 18, 2009, 16:13 |
Rep Power: 17 |
They are not arrays. When the subroutine is called, the solver will pass the i/j/k cell index and the subroutine will calculate the heat source per unit mass per unit time in that i/j/k cell, store the values in heatfl1/heatfl2 and then return heatfl1/heatfl2 to the solver.
You can use xi/yj/zk in the subroutine as it already include the meshcb module. |
March 18, 2009, 16:24 |
Re: About subroutine heatfl.F
James Zhong
Rep Power: 17 |
H.C, thank you for your reply! So since heatfl1 is not an array, if I want to define the heat flux for a specific cell at a specific moment, what I am to do is something like:
IF (t = xx AND i = xx AND j = xx AND k = xx) THEN heatfl1= xx Am I right? Thanks! |
March 18, 2009, 18:05 |
Rep Power: 17 |
Yes. I believe so.
March 18, 2009, 22:53 |
Re:About subroutine heafl.F
James Zhong
Rep Power: 17 |
Thank you!
April 16, 2012, 23:11 |
flow3d input gaussion heat
huanglin
Rep Power: 14 |
Could you help me?I modified the FORTRAN routine HEATFL to define a spatially varying heat source.How can I set variables in prepin.inp to call this modified soubroutine ?Do I just set dum=xx or idum=xx ?Is it necessary to compile HEATFL.f to HEATFL.obj?If so,where should I save them?Thank you very much!
April 16, 2012, 23:12 |
huanglin
Rep Power: 14 |
November 23, 2014, 20:38 |
#8 | |
Guangxi
Rep Power: 11 |
I'm doing the same thing as you have done years ago, since heatfl is power source per unit mass,when I define a gauss plane heat source, how can I convert power rate (unit: W) to power source per unit mass? In other words, when the power rate equal 1w, then heatfl= ?, thank you~ |
what subroutine is used? | nut | Siemens | 1 | December 8, 2006 13:56 |
subroutine | Tipakorn | Siemens | 0 | May 10, 2006 04:16 |
subroutine | Juliet | Siemens | 2 | November 27, 2003 18:52 |
Use subroutine | Moon | Siemens | 1 | March 13, 2003 07:49 |
Use Subroutine.. | Moon | Siemens | 1 | February 10, 2003 12:03 |
