Home > Forums > Software User Forums > FLOW-3D
difficulty on how to implement shot sleeve simulation in flow 3d cast
Like Tree1Likes
  • 1 Post By ankur singh
Old   October 10, 2014, 02:28
Smile difficulty on how to implement shot sleeve simulation in flow 3d cast
ankur singh
ankur singh is on a distinguished road
I was unable to do shot sleeve simulation( high pressure die casting) in flow3d cast ,any one plz me .
Thankyou
ankur singh is offline   Reply With Quote
Old   October 11, 2014, 01:16
ankur singh
Any one plz help
Old   October 13, 2014, 15:29
MC
melissa is on a distinguished road
Did you try the tutorials in the Help menu?
melissa is offline   Reply With Quote
Old   October 16, 2014, 09:59
ankur singh
Dear melissa,
I have done tutorial , but not completely understand things , like what is metal input , can I use this in high pressure die casting simulation. when I trying to run simulation with out use metal input, simulation progress show always 0% , but, when I use metal input ,simulation progress start increasing . so plz solve my this basics problem.
Xecus likes this.
Old   December 7, 2014, 16:34
Mohamed Refaat Abo El-Fotouh
Xecus is on a distinguished road
Same Problem here... Please any help
Xecus is offline   Reply With Quote
Old   December 25, 2014, 01:33
Ankur Singh did you solve the problem???
Old   December 27, 2014, 14:58
Dear ankur
Be careful for the signs of the velocity of the plunger.. To tell the software about the real direction you need
Old   January 23, 2015, 16:57
MC
Metal input is another way to define metal into the domain other than at mesh
To create the piston you must define a moving geometry
To define the fluid within the shot sleeve you will need to define a fluid region (Cast 3.5) as geometry Metal type
Old   January 24, 2015, 02:24
How much time the solver takes to calculate the problem? Please with the pc machine configurations
Old   January 26, 2015, 12:37
MC
Depends on number of cells, physics activated, and the flow velocities.
You can start to run the simulation and look at time step and divide that into estimated fill time to get an idea but the time step will get smaller as the velocity gets higher.
Old   April 6, 2015, 10:34
Default shrinkage porosity, surface defect, hot spot, air back pressure
  #11
ankur singh
can any one help me, to find out these result, i tried to much but can't find proper result , can any one solve my problem then i send STL model to their emails
[swak4Foam] installing funkySetFields prapanj OpenFOAM Community Contributions 65 October 8, 2015 17:46
1.5-dev GCC-4.5.1 linnemann OpenFOAM 22 November 3, 2010 03:09
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? randomid OpenFOAM Community Contributions 1 August 27, 2010 05:15
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
