October 13, 2008, 09:07 |
Complicated geometry for baffles
Hello dears users,
Is it possible to draw polygonal baffles, in order to build a infinitly narrow wall? Thanks Julien |
October 13, 2008, 11:50 |
Using STL file is possible?
Well, I think it is impossible. But I know that we can make initial fluid region and mass source/sink component as STL file.
So I suppose, can we monitor the flow rates using STL files? For example, We build a thin STL file and set iqsr=1, opor(n)=1, tobs(n)=0.~int, qsrobs(n,m)=0. then check the flux at STL component from general history. (But I didn't try it. Sorry. ^_^) |
October 14, 2008, 02:52 |
Re: Using STL file is possible?
In fact my purpose was to build a solid plane, not in order to measure a flowrate...I have already build a very thin wall, but I just wanted to know if it was possible to build such plane with a baffle...
Thanks for your response, that is what I have already use, a STL, but in my geometry. Julien |
October 14, 2008, 02:54 |
Thanks for your response, that is what I have already use, a STL, but in my geometry... Julien |
October 14, 2008, 03:38 |
yes, I know that you can use an STL to define a baffle (not simply a "volume" geometry).
I think it requires a customization that in FlowScience probably already exist, (or they'll add it to the new release) you can ask to FlowScience for that. |
October 15, 2008, 10:20 |
Hello Julien, You can use a baffle to act as a thin wall. You just don't select flux plane. Melissa
October 16, 2008, 08:12 |
Thanks Melissa,
but I need a polygonal geometry, not just a plane...that's why it seems to be complicated... Julien |
July 15, 2016, 17:18 |
#8 | |
hanif pourshahbaz
Rep Power: 9 |
i don't select flux plane to use baffles as thin walls half of this wall is in sediment and it acts like spur dike but when i use the FAVOR it didn't showed the part that is in sediment what should i Do? Thank you by the way |
Display Modes | |
[ICEM] Meshing on a Complicated Geometry | tav98f | ANSYS Meshing & Geometry | 2 | August 17, 2011 11:15 |
[ICEM] complicated geometry | imanmirzaiian | ANSYS Meshing & Geometry | 5 | July 6, 2010 10:14 |
Please help in meshing this complicated geometry | eers | Main CFD Forum | 7 | July 8, 2009 20:42 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
