-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Free Gridding vs BFG (http://www.cfd-online.com/Forums/flow-3d/27240-free-gridding-vs-bfg.html)
CK October 4, 2008 05:05
All Would like to understand if anyone have compared accuracy, simulation speed and effeciency between free griding from Flow-3D with others BFG (body fitted grid) CFD code?
Thanks and Regards CK
DTS October 6, 2008 18:59
Re: Free Gridding vs BFG
Dear CK,
Here is a general answer. Free gridding allows easy setup of both mesh and geometry. It also means good efficiency (overhead) and speed because neighboring cells are always known for calculations. FLOW-3D's FAVOR technique prevents the moment losses typically found in a structured grid so complex geometries can be captured with less resolution.
That being said, the disadvantage is when needing to locally resolve a mesh for boundary layer effects. An unstructured grid can give you the local resolution without carrying it through the entire domain. F3D does have a multi-block option that can help in certain cases.
Thank you, DTS
CK October 8, 2008 04:17
DTS Thanks for your comments.
Regards CK
