Q
Hi I am working with catia for produce stl file but when i use this file in F3D as component in preview i have this massage fatal error ie i/0. what can i do with this?
Thanks |
Re: Q
If the stl file is in text format, please try using admesh and converting the file into binary format. At the same time, you may also check if there are any errors within the stl geometry, like holes or wrong normals.
