Home > Forums > Software User Forums > FLOW-3D
units & stl file
Old   October 29, 2008, 06:26
Default units & stl file
Ali
Hi I am working with F3D 8.2 . I have stl file created with catia. this file is as obstacle. I have a problam when i want to set obstacle in channel.When i want to add this stl file i cant understand transform & region limiters.when i add this file my shape is deformed!!! Every body What should i do to solve this problem? Thank you very much
Ali
Old   October 30, 2008, 02:49
Default Re: units & stl file
Q
suggest building your composite model outside F3D, carefully processing surface normals, then load STL components incrementally. I use OpenGL based tooling to accomplish this which allows for grid point pulls, rotation, translations, scaling and copying. Feel free to send me your model for review.
[surface handling] How to make boundary patches in STL file nzy102 OpenFOAM Meshing & Mesh Conversion 4 January 22, 2018 15:03
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
